Author Topic: Sort order in project browser: not case sensitive  (Read 7221 times)
« on: November 17, 2011, 10:59:23 am »
It is possible to make the sort order NOT case sensitive in the project window. This would be very useful for reverse engineering databases (se SQL Server)
Re: Sort order in project browser: not case sensit
« Reply #1 on: November 17, 2011, 08:41:39 pm »
(Different DBs behave different in respect to case. Some are case sensitive per se while others are case insensitive.
q.)
« Reply #2 on: November 18, 2011, 12:18:03 pm »
Indeed, but the UI can moderate this behaviour.
I'd like to see an option for case insensitivity in the prohect broswer (and anywhere else where sorting occurs)
bschulz
« Reply #3 on: June 10, 2017, 04:09:18 am »
I'm trialing the software and already this is very irritating.
Guillaume
    • www.umlchannel.com
Re: Sort order in project browser: not case sensitive
« Reply #4 on: June 14, 2017, 02:02:41 pm »
I created a simple example and indeed get the following order: Class1, Class2, class1, class2, class3.
You can achieve a non case sensitive sorting on the elements names e.g. DB Tables with eaUtils free addin -> simply run the sort by Name on a package with the default non case sensitive values setting. I ran a test and get the expected order: class1, Class1, class2, Class2, class3
Help page: http://www.eautils.com/en/help/item/135-help-section-sort-elements-from-package-element-by-name
Guillaume
