Author Topic: Reset Project Home Default  (Read 6326 times)
kepNCI
« on: January 11, 2012, 08:19:24 am »
Maybe I am not seeting it, but I would like to reset the project so that it does NOT have a default/Home diagram. Once set, I only see how to change it to another diagram.
Aaron B
Re: Reset Project Home Default
« Reply #1 on: January 11, 2012, 09:27:14 am »
There is no explicit command to reset the default diagram, however a common workaround is to create a new diagram, set the new diagram as your model default, then delete the diagram.
HTH.
« Reply #2 on: January 11, 2012, 10:03:29 pm »
Aaron, this question has been asked many times. Why can't EA simply show "Make model default" as check mark in the context of a diagram. This way you could simply change and toggle off. Same for user default.
« Reply #3 on: January 12, 2012, 09:18:51 am »
snap, = feature request
