Author Topic: Adding HTML Tooltips to HTML Reports  (Read 6330 times)
Heidi Thomson
« on: January 12, 2012, 10:53:14 pm »
We are starting to document our models using the HTML output and have a feature enhancement for the template.
What we would like to be able to do is add tooltips to the diagrams so that when you hover over an element on a diagram, the notes associated with the element appear.  With the current #IMAGE# tag, I can't see a way of adding these tooltips without doing some complex post processing of the HTML output.
Is this possible?
Heidi
OpenIT Solutions
Re: Adding HTML Tooltips to HTML Reports
« Reply #1 on: January 13, 2012, 12:25:17 am »
Hi Heidi,
Not sure if its possible by creating and editing an HTML Template i'm afraid, but i'd like to also request this as a feature ! My boss has asked for the feature so ill be looking at the template option - if i come up with anything ill let you know.
Jon.
OpenIT Solutions
« Reply #2 on: January 13, 2012, 04:29:57 am »
I've had a good look at this now - and despite my lack of html/css/javascript skills i'm pretty certain that this can't be done without a change to the actual html generation within Sparx...it looks like the #IMAGE# tag not only adds the image, but also adds a <map> section to the html with associated <area> code this is where i'd add onmouseover code to display a tooltip containing the notes of the associated model element - but i think only Sparx could do this ?
Jon.
Heidi Thomson
« Reply #3 on: January 13, 2012, 08:02:16 pm »
Hi Jon,
Yes, this was my feeling as well.  I did wonder about doing some post processing of the HTML files but decided that was probably going too far.
Heidi
