Author Topic: OracleOleDB problem?  (Read 5374 times)
lubos
« on: April 20, 2010, 10:27:24 pm »
I begin to play with oracle and EA.
I connect to DB using Oracle Provider for OLE DB.
I have the following problem:
this SQL query>
select instr('Tag:Value',':') + 1 AS C1 from dual;
returns 5 in PL/SQL Developer
but
returns 41 when using it as as Custom SQL search in EA.
Is this a problem of OLE bridge?
Do you know how to solve it?
Thanks for any hints.
Re: OracleOleDB problem?
« Reply #1 on: April 20, 2010, 11:34:17 pm »
Quick look suggests a data typing problem...
try: select instr('Tag:Value',':') + '1' AS C1 from dual;
You should get '41' from both...
(Fingers crossed)  ;)
Isn't software wonderful?
« Last Edit: April 20, 2010, 11:34:45 pm by PaoloFCantoni »
lubos
« Reply #2 on: April 20, 2010, 11:44:07 pm »
OK I haven't described my goal :-)
I want to get  5 in EA search.
lubos
« Reply #3 on: April 21, 2010, 12:00:11 am »
I have overcome it by:
select instr('Tag:Value',':') - -1    as C1 from dual;
You'are right, software is wonderful ;-)
Still interesting in more appropriate solution...
« Reply #4 on: April 21, 2010, 12:08:22 am »
have you tried
select 5 as C1 from dual ;D
« Reply #5 on: April 21, 2010, 04:40:38 pm »
For your information,
On SQL Server both (ran through EA search)
select CHARINDEX (':', 'Tag:Value') + '1' AS c1and
select CHARINDEX (':', 'Tag:Value') + 1 AS c1result in 5
lubos
« Reply #6 on: April 21, 2010, 06:27:43 pm »
It's interesting,
I still have the result 41 in EA search. It seems it's a problem of some driver bridge...
But the hack with '- -' works so I will not continue to try to discover it.
