Author Topic: A question about the version of EA  (Read 10558 times)
czc
« on: January 31, 2012, 12:45:00 pm »
    After the version 7.0, first I select both MO and RO on one class,secondly I synch MO and synch RO, then the class will display a same tagged value.You can see the detail in the follow picture.
    I want to know the background of this change[ch65292]isn't normal change ? Thank you!
http://sourceforge.net/projects/pengao.u/files/class.jpg
http://sourceforge.net/projects/pengao.u/files/resources.jpg
« Last Edit: January 31, 2012, 01:23:41 pm by cleverchris »
Re: A question about the version of EA
« Reply #1 on: January 31, 2012, 05:57:23 pm »
I'm not sure if I understood the problem correctly, but if you need to be able to see tagged values with the same name then you must enable the option.
You can do that either from the tagged values window (the options button on the left of the question mark) or via Tools|Options|Objects|Show Duplicate Tags.
czc
« Reply #2 on: January 31, 2012, 10:35:26 pm »
When I sync MO and RO, I don't want it display same tag value. But after version 7.0,it occured. I am confused if this was the improvement or it was a bug.
czc
« Reply #3 on: January 31, 2012, 10:43:57 pm »
In the version 7.0,it displayed only one tagged values(such as "id"),but after the version 7.0,it will display two tagged values(such as two "id"). If this is a normal improvement,then we can't update to the latest EA version;otherwise I will wait for this bug be solved.Thank you!
« Reply #4 on: January 31, 2012, 10:47:55 pm »
Then uncheck the option if you don't want to see the duplicate tags.
czc
« Reply #5 on: January 31, 2012, 11:01:33 pm »
I developed a tool to opreate EA. Although uncheck the option can display only one tag,the tool will get two tag value also.The tool may not get the correctly value.
« Reply #6 on: January 31, 2012, 11:05:03 pm »
I'm pretty sure that this behavior is not a bug but intended, so I'm afraid you'll have to either fix the reason why the duplicate tags are created (by changing the profile) or change the tool you use to read the tagged values.
czc
« Reply #7 on: January 31, 2012, 11:30:31 pm »
Could I know the background of this change after the version7.0?   How Can I do if I want  return this function  to version 7.0 in the future version?
« Reply #8 on: January 31, 2012, 11:32:06 pm »
You'll have to ask Sparx that.
czc
« Reply #9 on: January 31, 2012, 11:36:44 pm »
I hope Sparx can see this post, thank you very much!
RoyC
  • Read The Help!
« Reply #10 on: February 01, 2012, 03:43:56 pm »
Only some of us can. You need to submit either a bug report or a feature request to Sparx Support, using the links in the Support column at the bottom of the forum screen.
Best Regards, Roy
