Author Topic: Glossary Rename -> Serach/Replace text  (Read 3752 times)
Stefan Kull
« on: February 24, 2012, 06:40:44 am »
When: During renaming/update of existing Glossary term via [Glossary Item Details]...
What: Add a "Search & Replace" option
Why: A time consuming task that easily could be automated :exclamation
What else: Need to adjust the scope for the Search&Replace, see list below...
  • Update element - Short description: [Yes/No/Automatic]
  • Update element - Notes: [Yes/No/Automatic]
  • Update diagram - Name: [Yes/No/Automatic]
  • Update diagram - Notes: [Yes/No/Automatic]
  • Update package - Name: [Yes/No/Automatic]
  • Update package - Notes: [Yes/No/Automatic]
Example : Before getting into construction(RUP) phase, we decided to clean up the glossary. Like all instances of "Supplier SSP Admin” should be replaced by “SSP Admin at Supplier”. This rename/replace action applies to both name & note field for...
  • Actors Diagram & Elements
  • Use Case Package, Diagram, Elements
  • Requirements Package, Diagram and Elements
  • Flow charts Package, Diagram and Elements
Consider repeating this for all 20 terms to be updated in my small/mid size project, without any tool...
...a lot of hands-on :'(
  • 18 Use Case with description texts
  • 160 Requirements
  • 15 Flow Charts
I also considered "exportXML-update-ImportXML" - but avoided due to 10 concurrent users of “my” package-branch in our EA Repository... (totally about 30-50 users)
  • From EA Repository, use package export to .XML
  • notepad.exe (Open + Search/Replace + Save) [smiley=thumbdown.gif]
  • DELETE package in EA Repository  <– Me don’t like[smiley=shocked.gif]
  • Import .XML package to EA Repository
Best regards
Stefan Kull
Senior business analyst
Södertälje/Sweden
« Last Edit: February 24, 2012, 08:30:07 pm by SSSQLL »
Stefan Kull
Re: Glossary Rename -> Serach/Replace text
« Reply #1 on: February 26, 2012, 01:40:20 am »
I found a Script on the http://community.sparxsystems.com that was made by Mr. Takeshi Kouno [smiley=dankk2.gif] at Sparx Systems Japan that will solve my the immediate need. See page: Replace text in Element Name and Notes
Please… package/present that functionally via a user friendly UI in the next SparxEA 9.3!
Right know the nerd-index is too high for a average business analyst.
  • Select if Interactive(With Replace/Next prompt) Automatic(Replace All)
  • Select how deep the search should go
Package Name[highlight][X][/highlight] Note[highlight][_][/highlight], Diagram Name[highlight][X][/highlight] Note[highlight][_][/highlight], Elements Name[highlight][X][/highlight] Note[highlight][_][/highlight] etc..
[/list]
