Author Topic: Objective-C support inSource Code Engineering  (Read 4360 times)
Rich Duncan
« on: March 15, 2012, 07:22:17 am »
We're working on applications that combine server side code (.NET & Java) with mobile apps written for Android and IOS.  Would love to be able to model and forward/reverse enginner Objective-C classes.  Given that the code is typically in SCM, it doesn't even need to run on OS X.
Re: Objective-C support inSource Code Engineering
« Reply #1 on: March 15, 2012, 10:22:33 am »
You should join others with the same request. Good luck with the search (use the left button, extend the search time).
Rich Duncan
« Reply #2 on: March 22, 2012, 04:21:47 am »
I'm not sure what you mean by "join others". I tried searching the forum for similar posts but didn't find any - that's why I created this one.  Can you clarify?
« Reply #3 on: March 22, 2012, 06:27:12 am »
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1326623971/7#7
Search this forum == PITA. Or for experts only.
« Last Edit: March 22, 2012, 06:27:54 am by qwerty »
