Author Topic: Erwin  model import error  (Read 3350 times)
Andrzejb
« on: April 22, 2010, 10:54:00 pm »
I try to import extract from Erwin 7.3 Data Modeler using metadata bridge for Sparx EA.
XMI import to EA fails with error message
"Element content is invalid according to the DTD/schema
Expecting {UML} Classifier."
I use UML_EA.DTD file
What is wrong ?
smendonc
  • I love YaBB 1 Gold!
Re: Erwin  model import error
« Reply #1 on: April 24, 2010, 05:06:24 am »
Try using 'OMG UML 1.x XMI 1.x' as the Type of export from ERWin. The use dtd option should be set to false.  I think this option is at the bottom of the list of options for this selection.  The resulting xmi can be imported into EA.  Unfortunately the Sparx EA export using metaintegration bridge from Erwin does not work as you noticed.
Stan.
