Author Topic: Deep Simulation Display and Debug  (Read 5316 times)
Nicole Tedesco
  • I don't think that's a good idea...
« on: May 01, 2012, 06:27:57 am »
Currently, EA (v9.3) will not follow the simulation of an activity below the local context.  For instance, if an Activity has a classifier, the simulation process will not follow the Activity "deep" into the classifier's stream.  I noticed this when I came across an infinite loop which occurred in the classifier's stream--the simulation looped (until I explicitly stopped it) but it did not display the classifier's stream where the aberrant loop occurred, nor could I set a break point on any part of the classifier's stream!
Please give me full access to my entire simulation stream!
Nicole C Tedesco
Re: Deep Simulation Display and Debug
« Reply #1 on: May 01, 2012, 12:10:42 pm »
Hi Nicole,
Did you submit a formal Feature Request using the link below?
If not, please do so as this is purported to be a user forum.
« Reply #2 on: May 01, 2012, 02:30:35 pm »
Not sure what is going on for you. But I've tested with simulations with recursive calls and even the equivalent of a fork bomb and it showed what I expected.
