Author Topic: Non-modal dialogues  (Read 6430 times)
Doug Blake
Non-modal dialogues
« on: May 03, 2012, 06:07:46 pm »
I dont know how others feel, but the situation I am in at the moment is that my team are writing up Use Cases and Scenarios. So I open up the Use Case properties dialogue, only to want to see what I did in another use case. The modality of the dialogue box means I have to close one before I can open another, when ideally, I would like to see both at the same time.
So, whos up for non-modal dialogues and is it feasible wrt the database?
DGB
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
SomersetGraham
Re: Non-modal dialogues
« Reply #1 on: May 03, 2012, 06:10:53 pm »
I open 2 instances of EA!
Using V12
« Reply #2 on: May 03, 2012, 07:03:01 pm »
I use the docked scenario's window + the EA Navigator to find the use case I was working on again.
« Reply #3 on: May 03, 2012, 07:19:51 pm »
Attributes/Operations are non-modal. If you select another element the according list is updated. So yes: why does the main properties window behave different?
