Author Topic: Synchronize Package Content Window  (Read 4019 times)
Josef Stadelmann
  • as simple as possible, but not too simple
« on: June 22, 2012, 03:56:18 am »
on a Reverse engineering (source to model) operation raido button set, one can toggle with or without child packages
Now - my childs are a huge java frame work, all stuff previously read and put into its own frame work package, such as java, javax, sun, etc. you know the larger JAR's.
While I did not know first what childs are, I said yes once. Upss, Then the import started and and afte a while resulted in a error msg box poping up. Errors caused by jar files. The only option was a box with Yes or No but not CANCEL.
While in certain situations Yes and No is OK, if this errors happens because there is a problem with importing from the JAR's, or other binaries, such as .NET dll's, one of those real huge JAR's, or DLL's, the only option is then to kill the EA process.
I suggest to improve the overall situation for EA. When a EA operation can potentially last too long or when a chance developes that too many errors will be reported, developers should think about how to abandon then the current operation for a clean exit to main EA menues. All else puts your model at risk to get corrupt after a while.
Josef
« Last Edit: June 22, 2012, 04:02:56 am by stadelma »
