Author Topic: PL SQL package reverse engineering  (Read 6449 times)
MastaKilla
« on: December 21, 2007, 04:09:52 am »
We are using EA as a metadata and model repository for large Oracle project. We do use reverse engineering and code generation on everyday basis.
Is there a solution (add-in, template) to reverse engineer PLSQL package to the point of having its real functions and procedures represented under package as operations?
Currently EA provides reverse of PLSQL package as
Package: Package name
Package operations:
<<package spec>>specification() operation as for package speciffication
and
<<package body>>body()
where whole code for each part is stored in Behavior:Initial Code.
We are looking for soultion to reverse package into a following representation. For example:
Package:Package name
Package operations:
<<function>> Function_1(int)
<<function>> Function_2(int)
<<procedure>>Procedure_1
I would strongly appreciate  any help with this.
Ivan
« Last Edit: December 21, 2007, 04:11:10 am by MastaKilla »
rsipin
Re: PL SQL package reverse engineering
« Reply #1 on: January 17, 2012, 03:26:16 am »
I would strongly agree. We manage nearly 100 different systems, and the only languages which we cannot use EA for is our database embedded code. It's not a trivial matter by any means to keep Packages and Operations in synch by hand with large database systems.
mbald
  • I love Enterprise Architect!
« Reply #2 on: September 18, 2012, 02:09:59 am »
We would appreciate some news or support regarding this topic as well.
It would be perfect to be able to import procedures/functions of PL/SQL packages as operations of a class (with stereotype <<package>>).
Like this the operations could be reused within the entire model. E.g. in sequence diagrams.
Michael
RoyC
  • Read The Help!
« Reply #3 on: September 18, 2012, 10:11:06 am »
Perhaps you could submit this as a feature request to Sparx Support, using the link in the Support column at the foot of this page.
Best Regards, Roy
