Author Topic: Enable per class 'Advanced' settings for Code Eng.  (Read 3750 times)
g.makulik
« on: November 23, 2012, 07:18:27 am »
I've recently sent a bug report to Sparx that the 'Advanced' settings set with the 'Generate Code' command for a selected (Class) element doesn't change anything for this particular element's generated code (I was particularly referring the 'C-Language->Object Oriented Support' option).
Their answer was that this behavior is intended and this(those) option(s) won't be considered on class level.
Well the options sections are titled 'Options for the current model/user', though your value changes will be saved and recalled on class level. I find this behavior pretty misleading, either changing such settings should be disabled or not accepted to be saved (at class level).
Most of those options I would find pretty useful to be configured on class level anyways.
Thoughts, experiences or workarounds anyone?
Günther
This
