Author Topic: EA.exe blocking external resources  (Read 3312 times)
gilles2
« on: May 05, 2010, 07:50:48 pm »
Hi all,
I am having a strange issue.
I have developped an external tool that connects to an EAP file through the API.
Everythings works fine !
I use ExportPackageXMI method on Project object.
It works.
But the EA.exe process linked to my tool blocks a particular resource after calling the ExportPackageXMI  method. The directory containing my xmi file generated is blocked by the process.
I need to disconnect from the EAP file to be able to work on this directory (delete,....) which is not convenient in my tool.
Do you have any idea ?
Tx
Gilles
