Author Topic: Local path in tab "Files" of class  (Read 10034 times)
Michal C.
« on: June 24, 2010, 06:11:05 pm »
Hi
We use Control Version on projects. In dialog "Package Control Options" we specify XMI filename using "Local Path". This is usefull, because each user can define local path for working copy.
But problem is with "Files" tab on properties of class dialog. In "File path" field I can't use Local Path.
This mean, that links to files can't be used on users workstation (Launch button) beacause users have different paths to working copy.
Is it problem to enable Local Path in this place?
Or is any solution?
lubos
Re: Local path in tab "Files" of class
« Reply #1 on: June 24, 2010, 08:52:21 pm »
this problem was reported "years" ago and changes were promised but it is still not solved.
I can not find the discussion thread now but I vote for this behavior again too.
« Reply #2 on: June 25, 2010, 08:23:47 am »
I believe it has been implemented and just needs to undergo appropriate testing before being accepted into a release.
AlexY
« Reply #3 on: July 07, 2010, 11:38:37 pm »
Hi Simon,
does it apply (will it be implemented?) also to local path in Filename property of element?
Alex.
Michal C.
« Reply #4 on: August 05, 2010, 08:19:46 pm »
I hope, this feature will be implemented before expiration of my subscription ;)
Michal C.
« Reply #5 on: February 05, 2013, 11:35:13 pm »
...three years later....
Is it problem to enable Location %xx% from version control in Local Path ?
Like XMI Filename: %MyRepo%\Class Model.xml ?
« Reply #6 on: February 06, 2013, 12:03:36 am »
If I interprete Simon correctly there is a very thorough testing done at Sparx  ::)
