Author Topic: Bookmarking or Favorites Improvement  (Read 5990 times)
tria1312
« on: March 08, 2013, 06:29:01 pm »
I would like to have an intuitive usable bookmarking system like it is in Firefox. I thought, I found it as I discovered the favorites view. But:
  • I wasn't able to add any element to the favorites folder in the view using an intuitive way and
  • as I read the help I was suprised that only elements and NO diagramms could be added
Best Regards
tria1312
Re: Bookmarking or Favorites Improvement
« Reply #1 on: March 08, 2013, 09:50:56 pm »
Well, it's not like Firefox bookmarks, but it's called bookmark. Select an element in a diagram an press shift space. A little red triangle appears on top of the bookmarked element. With Ctrl-F you can find bookmarked element with the appropriate search.
tria1312
« Reply #2 on: March 08, 2013, 09:53:02 pm »
Yes, I know about this feature. But
  • can I set several Bookmarks.
  • And where can I find them as a list.
tria1312
« Reply #3 on: March 09, 2013, 03:15:42 am »
There's one bookmark per element (and only settable via a diagram). To find it (as already said): Ctrl-F, Find Bookmarked Elements.
Aaron B
« Reply #4 on: March 12, 2013, 10:50:52 am »
You can also create a Favorites folder in the Model Views window which allows you to keep links to frequently used elements and diagrams.
See:
http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/navigate_search_and_trace/model_views.html
Under a Model View root node you can create Views folders that can contain Search View folders, Slideshow folders and Favorites folders.
A Favorites folder gives you easy access to commonly-used items in the Project Browser; to create hyperlinks in a Favorites folder to the required items in the Project Browser, drag items from the Project Browser into the Favorites folder
