Author Topic: Auto-select message upon creation  (Read 3756 times)
« on: May 01, 2013, 02:41:22 am »
Currently if you create a message to an object EA puts the focus on the target element, not on the created message. The way I use the tool is to create and then edit the message to assign a method name. Unfortunately again, it looks like the message is selected, but it isn't. So the Enter key following the creation will open the object properties. It would be soooo nice if this use case would be supported.
And NO, the option "edit connector on create" is not an option since I want to do this only with the minor number of messages and NOT with all the other connectors. Honestly I don't want a new option for that too unless the other options get a meaningful structure! The current one is not really prepared to win an UI design award.
Re: Auto-select message upon creation
« Reply #1 on: May 07, 2013, 07:11:01 am »
Nothing to say?
