Author Topic: State machine and profile  (Read 6676 times)
utilisateurEA
« on: May 04, 2010, 07:31:57 pm »
I am trying to create a profile with a composite diagram.
The "son" diagram must be a State Machine diagram.
I created a profile where, in my diagram type part, I created a metaclass object named Diagram_StateMachine and a stereotype object linked with an extends.
The name of the stereotype object is the name of my kind of diagram.
If in my metaclass I write Diagram_Sequence or Diagram_Use Case I have the correct type of diagram (seq or Use case). Every diagram works except State Machine. Do you know how to do it (maybe there is a particuliar way to write State Machine ? (but I tried a lot of combinations))
Thank you.
Re: State machine and profile
« Reply #1 on: May 04, 2010, 08:19:05 pm »
Which combinations did you try?  Just for interest's sake.
However, it seems to me that if you want your stereotyped element to have a __defaultDiagramType to be one of the existing diagram "types".  You should be able to just set the _defaultDiagramType attribute to the appropriate initial value.
I think (but who knows with EAUI) that you only need to «extend» the Diagram_XXXX metaclass if you are defining a new type of diagram.
utilisateurEA
« Reply #2 on: May 04, 2010, 09:18:30 pm »
What do you mean ?
I don't want exactly a State Machine. I want a customised state machine with the appearance of a classic one (the icon in the project browser for example)
« Reply #3 on: May 04, 2010, 10:48:13 pm »
What do you mean ?
You said you used various combinations of "State Machine"...
Which ones?
utilisateurEA
« Reply #4 on: May 04, 2010, 11:44:12 pm »
I was probably not clear : I just meant that I tried several ways to write Diagram_StateMachine like Diagram_State_Machine or Diagram_State Machine.
Nothing extraordinary !
« Reply #5 on: May 05, 2010, 08:42:47 am »
http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/defining_child_diagram_types.htm gives the list of valid values for _defaultDiagramType.
From that I believe you want 'UML Behavioral::State Machine' without the quotes.
« Reply #6 on: May 05, 2010, 09:59:25 pm »
Simon,
That's not utilisateurEA's problem...  defaultDiagramType was a side issue.  Sorry.  I was just trying to supply a work around.
His problem is "what do you name the Metaclass from which you extend to define the child diagram?"
utilisateurEA can you confirm that?
« Reply #7 on: May 06, 2010, 09:07:20 am »
Thank you.
Diagram_Statechart. See this page for the full list.
