Author Topic: how to work in a group at the sime project EA  (Read 5206 times)
m.oualialami
« on: May 01, 2013, 12:33:43 am »
how to work in a group at the sime project EA :
I wonder if there's a possibility of it working in the same project
and thanks
Re: how to work in a group at the sime project EA
« Reply #1 on: May 01, 2013, 01:27:03 am »
See Sparx' white paper for configuration management (should be in the Resources page).
P.S.: http://www.sparxsystems.com/downloads/whitepapers/EA_Deployment.pdf
« Last Edit: May 01, 2013, 01:29:49 am by qwerty »
Helmut Ortmann
« Reply #2 on: May 04, 2013, 12:42:45 am »
It depends from your requirements and your group size.
For professional working with a lot of users consider using a DBMS.
For just trying something or small groups you may use a shared *.eap file. If you use a shared *.eap file in a group be aware that problems may occur. It depends from ... I don't know.
If you have a complex project with special requirements consider requesting help.
Here in the forum you will find a lot of information from different viewpoints for this topic.
Best regards,
Helmut
HJA
« Reply #3 on: July 03, 2013, 06:24:59 pm »
Hello Helmut,
i will follow the dbms approach.
Using Oracle databases...is it necessary to have a diffrent user/schema with tables for each projekt i want to transfer to the dbms ?
Thanks for your help,
Hans-Jörg
Helmut Ortmann
Re: how to work in a group at the same project EA
« Reply #4 on: July 03, 2013, 06:36:39 pm »
Hello Hans-Jörg,
each EA- Repository in Oracle is represented by a user / schema. That's the same logic as with a *.eap file.
Whether you use one repository for one project or one repository for all projects depends on your requirements.
Helmut Ortmann
