Author Topic: Import tables from AS400  (Read 6175 times)
JulianEscobar
« on: July 16, 2013, 12:31:35 am »
Good Morning,
When i use EA 7.3,  i can import tables from AS400,  but when i upgrade EA,  to 9.3 or 10,  i 'can't import tables from AS400. Can you help me?,  I was using the same ODBC that works with 7.3 version (iSeries Client Acces).  i don't know if the problem induced from ODBC or EA.
The message is "Database could not be opened".  "Error retrieving table list".
When this message not show,  the list of tables is empty.  :'(
Helmut Ortmann
Re: Import tables from AS400
« Reply #1 on: July 16, 2013, 06:37:22 am »
there are some general ideas to find the issue:
1. Get the SQL statement which cause the problem
%APPDATA%Sparx System\EA\DBerr.txt
2. Has you updated to the current ODBC Driver?
3. Have you searched the forum for AS400
4. 32bit or 64bit OS
Helmut
JulianEscobar
« Reply #2 on: July 16, 2013, 07:45:44 am »
1. I can't find DBerr.txt file.
2. No,  actually I use 11.00.00.11 version.
3. No,  I haven't
4. 32bit and 64 bit OS
I don'n know how to upgrade my ODBC Driver,  but i have found thahtthere  are recent versions,  so i need information about where can i find this versions.
Can you help me?
« Reply #3 on: July 16, 2013, 08:07:37 am »
Re 1.: Type %APPDATA% in the explorer. Then navigate further to Sparx System\EA\DBerr.txt
I can't remember any recent post dealing with AS400. So the search might be futile.
JulianEscobar
« Reply #4 on: July 18, 2013, 06:57:12 am »
Re:Re 1: I found the path,  but the file doesn't exist.
About the drivers,  I was able to upgrade them,  but it is not working (import from database)
« Reply #5 on: July 18, 2013, 07:05:08 am »
Send a bug report to Sparx (bottom right of this page).
As a work around you still can import via 7.3. Just rename the 7.3 programs folder to EA7.3 (or the like) and install the new version. You can the run 7.3 juts for the import.
JulianEscobar
« Reply #6 on: July 18, 2013, 07:40:33 am »
Ok,  i send a bug to sparx.
About to rename the folder,  i can't do that,  because the activation key is in a shared service that is not be available to select on 7.3 version.
« Reply #7 on: July 18, 2013, 08:12:40 am »
You should contact Sparx support to help you out. They are quite responsive in such cases.
