Author Topic: BPEL Loop Modeling  (Read 3412 times)
tpurtill
BPEL Loop Modeling
« on: May 08, 2010, 03:11:47 am »
Can anyone help me with creating the contents of a BPEL loop element; that I can then use to generate the correct BPEL output.
The loop element allows the loop conditions to be defined; but not the contents (I.e.  Activities performed within that loop).
Does anyone have a simple example they can share with me?
If I attempt to create a BPEL subprocess for the loop to define its contents it always fails "BPEL Generation" because it either:
 - Generates an error stating there are too many start events for the overall process; and when the start and end events are removed it;
 - Generates an error stating the subprocess does not adhere to the BPEL standard.
Is there anyway I can direct the sequence flow from the parent process to the first activity in the child loop process definition?
Tim
