Author Topic: SysML 1.3 Activity Diagrams  (Read 4770 times)
philchudley
« on: November 20, 2014, 09:26:39 pm »
Support for SysML 1.3 has imported significantly over the versions. We now have much closer alignment with the OMG Spec, particularly in the area of Blocks / Ports and Block / Requirement Compartments.
However one area is still lagging behind, namely Activity Diagrams
Apart from some stereotypes it is pretty much the same as UML
With version 12 upcoming may I request the following enhancements
1) Dashed lines for Control Flow (as per OMG SysML 1.3 spec)
2) Support for Parameter Sets
3) Stereotypes visible for Activity Parameters and Action Pins (for example <<optional>>
4) Alternate format for Interrupt Flow, that is as a "normal" Control / Object Flow, but with a small "lightning bolt" floating (like a label) near its middle
5) Re-sizeable Activity Parameters so that the name can be placed inside the Parameter symbol
Many thanks for your consideration
Models are great!
