Author Topic: Allow Common Table Expressions in custom search  (Read 3595 times)
Mike Hatch
« on: February 27, 2015, 10:36:34 am »
When defining a custom search using SQL, it would be useful to be able to use a Common Table Expression (CTE) when using SQL Server.  Currently the tool does not throw an error, but does not execute a statement that begins with a CTE.  Here is an example  query that would build a path to the current object by using a recursive CTE to find the Parents of the object.
;With Hierarchy (Object_ID,Name,ParentID,Path)
AS
--Anchor query defines the first non-recursive query
SELECT p.Object_ID,p.Name,p.ParentID, CAST(p.Name AS varchar(max)) as Path
FROM t_object p
LEFT JOIN t_object t
ON t.ParentID = p.Object_ID
WHERE p.ParentID = 0
UNION ALL
--Recursive query
SELECT t2.Object_ID,t2.Name,t2.ParentID, CAST(h.Path + '->' + t2.Name AS varchar(max))
FROM Hierarchy h
INNER JOIN t_object t2
ON t2.ParentID = h.Object_ID
--output query using the CTE defined above
SELECT distinct Object_ID, Name,ParentID, Path
FROM Hierarchy where ParentID <> 0
OPTION (MAXRECURSION 0)
« Last Edit: February 27, 2015, 10:39:52 am by mihatch »
Re: Allow Common Table Expressions in custom searc
« Reply #1 on: March 07, 2015, 01:36:40 am »
+1
