Author Topic: Connecting an Activity to an ActivityPartition  (Read 4815 times)
Ralf
« on: May 15, 2010, 07:04:52 am »
while trying to generate my own BPMN 2.0 technology file, I get a problem to connect an Activity (UML-Type Activity) with a Pool (UML-Type ActivityPartition). Everytime I try to draw such a connector, I get a
"The requested Connection is not UML compliant"
error message.
Everything else works fine by now (quicklinks, toolbox, diagram, stereotypes etc).
Does anybody have an idea?
PS: I'm using a ControlFlow to connect...
« Last Edit: May 15, 2010, 07:08:08 am by FloydDread »
Re: Connecting an Activity to an ActivityPartition
« Reply #1 on: May 15, 2010, 09:35:32 am »
Are you able to make the same connector manually?
If not, then you need to fix that problem - probably by using Tools|Options|Diagram [ ] Strict UML Syntax
« Last Edit: May 15, 2010, 09:37:07 am by PaoloFCantoni »
Ralf
« Reply #2 on: May 15, 2010, 05:44:39 pm »
No, can't do it manually, but somehow the standard BPMN technology manages to create this connection.
I thought that it is maybe possible to disable the UML checking in a profile...
But I've now switched it from a ControlFlow to a Dependency. That works!
« Reply #3 on: May 15, 2010, 05:59:02 pm »
If you change the UML setting - does it allow the connection in the AI?
Are you changing the dependency to a control flow afterward?
« Reply #4 on: May 17, 2010, 09:31:23 am »
The BPMN diagram is an extended Analysis diagram. EA doesn't do syntax checking on Analysis diagrams.
Ralf
« Reply #5 on: May 18, 2010, 04:21:13 am »
thanx! good to know. This solves my problem!
