Author Topic: API: Return Pkg / Obj IDs from DocumentGenerator  (Read 5600 times)
Uffe
« on: June 02, 2015, 01:40:47 am »
Hey hey!
Hedging my bets in case no one likes my relevant-glossary idea. :)
When using the DocumentGenerator, it would be very useful if the various methods would return not booleans (worked / didn't work) but collections containing the package and object IDs for which templates were called, ie every package and object whose IDs were in context as #PACKAGEID# / #OBJECTID# during the generation.
Since templates can call other templates, and follow all sorts of relationships in addition to the package / element hierarchy, this information is non-trivial to retrieve beforehand, but should be easy-peasy to pick up as the generator goes along.
Ideally, the templates that were used should be indicated as well.
Cheers,
/Uffe
Re: API: Return Pkg / Obj IDs from DocumentGenerat
« Reply #1 on: June 03, 2015, 08:16:41 am »
Personally, I'm a big fan of functions providing more information than a single boolean. Unfortunately, without completely duplicating the methods the signatures can't be changed because they would break existing applications.
