Author Topic: Additional multiplicity functionality  (Read 8019 times)
« on: September 04, 2015, 05:51:57 pm »
EA currently gives you the ability to alter the multiplicity of one end of the arc directly on the diagram via the context menu when at that end of the arc.  When you are setting up an arc that allows multiplicity (Associations, Aggregations and Compositions). you need to set up both end of the arc.
It would be REALLY COOL to allow the user to set both ends at once by adding a context menu item when not at either end.  THe multiplicities could be indicated by Origin -> Destination.  For example:
1..* -> 1 would indicate a mandatory many to mandatory singular relationships.
What do others think?
Re: Additional multiplicity functionality
« Reply #1 on: September 14, 2015, 07:10:39 am »
+1
« Reply #2 on: September 14, 2015, 03:27:05 pm »
Even simpler: The "Other" dialogue could take a 2nd input to specify the multiplicity for the opposite side. That should be fairly easy to implement.
« Reply #3 on: September 16, 2015, 05:53:42 pm »
Want!
