Author Topic: Diagram compartment for Packages  (Read 9682 times)
« on: October 20, 2015, 07:23:24 pm »
We've decided to move the VAST bulk of our objects into a specific branch for them and the diagrams remain in other branches.  One thing we've noticed is that there's no way to indicate the diagrams within a package within the package rendering.
Could an additional option be made available on the Feature and Compartment Visibility [Ctrl+SHift+Y] dialog - specifically for packages that says [ ] Show Diagram?
Perhaps, a new Diagrams compartment would be useful?
Uffe
Re: Diagram compartment for Packages
« Reply #1 on: October 20, 2015, 07:39:06 pm »
+1
Glassboy
« Reply #2 on: October 21, 2015, 02:26:49 pm »
Could you use a "Package as List" ModelView and change what it's displaying?
« Reply #3 on: October 21, 2015, 02:37:23 pm »
Hi Glassboy,
As a VERY temporary work-around it can be done.  You need to "twiddle" the Custom SQL, but it's doable.  However, you don't get to see the other compartments - which was the reason for my request.  In other words, in this rendering,  it's not a coherent object on the diagram.
But thanks for the pointer!
« Reply #4 on: December 11, 2015, 07:57:09 am »
+1
and also represent package as a box, rather than a  tabbed entity
« Reply #5 on: December 14, 2015, 10:50:29 am »
Do you mean provide "Rectangle Notation" for a package?
« Reply #6 on: December 14, 2015, 11:12:11 am »
That's what I wanted to say  [smiley=dankk2.gif]
« Reply #7 on: December 14, 2015, 07:00:31 pm »
+1
Yes, the standard method for getting the [ ] Use Rectangle Notation for a vertex (via shapescript) doesn't work for packages...
Even if you "jam" the DB with the appropriate ObjectStyle value, it won't render as Rectangle Notation.
Glassboy
« Reply #8 on: December 15, 2015, 07:06:22 am »
Paolo what do you mean by the term vertex?  Your context seems to be for a shape not the corner of a shape which confuses me.
« Reply #9 on: December 15, 2015, 10:52:46 am »
Unfortunate that there are dual applications of the term vertex in this context.  I meant the shapes that are vertices of the graph that is the diagram, not the shapes that are the arcs of the same graph.
It's really hard to get a clear vocabulary since all the terms overlap so much.
Both shapes that are vertices of the graph that is the diagram, and the shapes that are the arcs of the same graph are UML Elements (although Sparx separates them prematurely - in my view).
Since the shapes (of both kinds) are also graphs, it's a bit recursive.  I use way-points for the shape vertices.
