Author Topic: Accessing audit revision numbers  (Read 4046 times)
David OD
« on: May 20, 2010, 10:15:12 am »
Hi all
I am generating documention from models, and for particular elements, want to provide the following details:
Version No X.X  Revision No XX  Last Edited XX/XX/XX
I can easily get the first and last bits of this, but the Revision obviously comes from the auditing.  I can't find any API call that provides access to this.  I can't even see a table (t_something) in the database that contains the information so I can do a SQL query.
I know it is possible, as RaQuest shows the data.
Do any of you gurus know how to access this information?
Regards
Re: Accessing audit revision numbers
« Reply #1 on: May 20, 2010, 03:18:55 pm »
David,
I don't know it by heart (we don't use auditing), but whenever I need to find out something like this I do following:
- Start with an empty model
- Do the absolute minimum to get the data that you need
- Open the model file with MS Access
- Open every table and inspect its contents untill I find what I need.
David OD
« Reply #2 on: May 21, 2010, 12:19:41 pm »
Thanks.  Not what I wanted to hear, but probably a very accurate approach!!!  I just found out where matrix profiles were located, so next stop, audit data!  ;)  If I find it I'll post the answer.
Regards
