Author Topic: Add or delete an element from a diagram  (Read 16186 times)
tzafrir
« on: December 26, 2015, 08:32:01 am »
I have an element that i want to add to a specific diagram through the API.
And I have an element that I want to remove from the diagram.
I could not find an API that does that.
Does anyone know how this can be achieved?
Tzafrir
Re: Add or delete an element from a diagram
« Reply #1 on: December 26, 2015, 05:54:32 pm »
You have to create a new diagram object on the diagram
EA.Diagram.DiagramObjects.AddNew()and then set the elementID of that diagramObject to the elelementID of the element you want to add.
Removing is the same principle, remove the DiagramObject using
EA.Diagram.DiagramObjects.DeleteAt()
tzafrir
« Reply #2 on: December 27, 2015, 06:21:17 pm »
I tried to use those APIs, but none of them work as I expect. I am probably missing something here.
I will use a sample code to be more clear:
For the AddNew API:
EA.Diagram diagram = repository.GetCurrentDiagram();
EA.DiagramObject diagramObj = diagram.DiagramObjects.AddNew("ABC", "Class");
diagramObj.ElementID = someElement.ElementID;
diagram.Update();
For the delete API:
short id = (short)someElement.ElementID;
diagram.DiagramObjects.DeleteAt(id,false);
(This is throwing an exception on an element that is on the diagram)
I think I used them both properly, can you assist me with what is wrong?
Tzafrir
« Reply #3 on: December 27, 2015, 06:48:21 pm »
You forgot to save the DiagramObject using Update()
tzafrir
« Reply #4 on: December 28, 2015, 07:33:58 am »
 :( I know it should be simple but I am missing something basic here:
For the Add method all I want to do is get an element and put it on the diagram
this simplify what I wrote:
private addToDiagram(EA.Repository repository,EA.Element someElement)
    EA.DiagramObject a = diagram.DiagramObjects.AddNew(someElement.Name, someElement.Type);
    a.ElementID = selected.ElementID;
    a.Update(); //The update is throwing an exception
    diagram.Update();
In debugger I see the element Id is getting updated, but the Update throws an exception.
For the delete function, all it should do is get element an element which is on the diagram and delete it:
private deleteFromDiagram(EA.Repository repository,EA.Element someElement)
  short id = (short)selected.ElementID;
  diagram.DiagramObjects.DeleteAt(id, true); //this line throws an exception for a valid element
  diagram.Update();
Again, what is wrong with this delete?
 Tzafrir
« Reply #5 on: December 28, 2015, 03:13:07 pm »
tzafrir
« Reply #6 on: December 29, 2015, 05:35:26 am »
Sorry for the confusing sample, in my code I use someElement, this was a typo when I created the mail
Anyway I changed the addNew to get the position and still getting this exception:
   EA.DiagramObject a = (EA.DiagramObject) diagram.DiagramObjects.AddNew("l=200;r=400;t=200;b=600;", "");
   a.ElementID = someElement.ElementID;
   diagram.Update();
For the delete function, i saw that the element was deleted by using the count method but the diagram was not updated in model (with the update and refresh methods)
  int i = diagram.DiagramObjects.Count; //2
  diagram.DiagramObjects.DeleteAt(1, true); //delete the second element in diagram
   i = diagram.DiagramObjects.Count; //1
   diagram.DiagramObjects.Refresh();
   diagram.Update();
The sample code I saw in the forum looks pretty much like mine, but something is still missing...
« Reply #7 on: December 29, 2015, 06:31:48 am »
You have to reload the diagram before you see any changes, and you don't need the refresh() operation. (you hardly ever need Refresh())
You might need to lose the diagram.update() as well. That might undo the delete you just did on the diagramObjects collection.
As for the exception, it might help if you post the actual exception
tzafrir
« Reply #8 on: December 30, 2015, 03:55:03 am »
Add element to diagram was resolved but the requested element for deletion is not deleted from diagram.
What I see is:
diagram.DiagramObjects.DeleteAt(index,true) does delete the element,
as mentioned above i can see the size of diagramObjects is reduced by 1.
I removed the diagram.DiagramObjects.Refresh().
and run it with and without diagram.Update() API call.
both cases element stays on the diagram.
I also run a test that add a new element to a diagram and it is shown when closing and opening the diagram.
(So diagramObjects are getting refreshed but without the deletion)
Any other ideas?
« Reply #9 on: December 30, 2015, 07:05:54 am »
I'm not sure what you are doing wrong, but this bit of VBScript removes a single DiagramObject each time it is executed.
I added the ReloadDiagram so you can see it without having to close/reopen the diagram.
sub main
dim currentDiagram as EA.Diagram
set currentDiagram = Repository.GetCurrentDiagram()
if currentDiagram.DiagramObjects.Count > 0 then
currentDiagram.DiagramObjects.DeleteAt 0,true
end if
Repository.ReloadDiagram(currentDiagram.DiagramID)
end sub
main
tzafrir
« Reply #10 on: December 30, 2015, 08:45:05 am »
The repository.ReloadDiagram(diagram.DiagramID) solved all my issues
« Reply #11 on: December 30, 2015, 03:04:57 pm »
That means it worked before too, you just didn't see it.
