Author Topic: Heat Map Series, grouping, and sizing  (Read 4734 times)
ssands
« on: December 29, 2015, 03:50:32 pm »
Hi all,
I'm a bit confused about Heat Maps. I have an set of "class" elements that are stereotyped as "Features". Each has two custom tags (lets call them Tag1 and Tag2).
I want to create a heat map with the grouping by Tag 1 value, and the sizing in each group by the tag2 value.
I don't see a way to do this in the interface, so I'm guessing that I need to use custom SQL. Is this correct?
Any tips on how to access a tag value via SQL?
I'm sure this is in the user guide, but haven't found it yet.
Pointers to the docs appreciated.
barracliffe
Re: Heat Map Series, grouping, and sizing
« Reply #1 on: February 15, 2017, 10:44:52 am »
I am having the same problem trying to create Heat Maps. It is not very intuitive.
