Author Topic: How can behavioral code generation recognize classifiers in other packages?  (Read 8181 times)
otimitech
Fellows,
I need behavioral code generation to recognize classifiers from other packages.
Because I wish to mantain one package for system itself, other(s) for libraries and frameworks (it makes sense, right?).
So, sometimes a system class' attibute is of a type from library package.
But, when I try to generate behavioral code, I get only "/*Warning:  - No valid classifier set!*/" in code.
It works only when I put library package INTO system package, but it doesn't make sense in my mind.
Is there some kind of importing I can use, so I don't need to put library package into system package; in order to behavioral code generation could recognize classifiers into those libraries?
Thanks in advance and happy new year from Brazil.
« Last Edit: January 04, 2016, 07:38:03 am by otimitech »
otimitech
Well, all I need is a way I could group classes as a package (just for organization) but allowing generate code for each class separately.
I've tried:
  • Packaging component - but have same problem with package
  • Component - doesn't not allow code generation for classes inside it
  • Class with custom stereotype - just a disaster
Please, is there no way to simply import classifiers from a package (or other kind of grouping) to another, allowing behavioral code to be generated as if they were all in the same package?
How can I have a simple library with common stuff, if EA does not make available a way to group classes and generate behavioral code using this library?
I can't just duplicate classes I need in every package...
Please, any help?
« Last Edit: January 04, 2016, 07:50:04 am by otimitech »
armand.moutchiho
I am currently trying to assess Enterprise architect for our future business and I am running into a quite similar problem. I want to run a basic activity simulation where I call  an operation. The class the method is from is in another package where I organize classes. The simulation seem not to be able to recognize the class(frankly , I would not have expect this, as it is quite trivial and basic).
Did you found a solution for your problem please?
Is there some kind of special settings which I have to do?
Best Regards
Armand
