Author Topic: HTML creation : diagram image quality (SOLVED) and icons quality (Solved-ish)  (Read 7819 times)
Oopah
Hi all,
When I changed from EA 11 to 12, I noticed that the quality for the diagram image went down in the HTML documentation generated. Would you know how to get the image to a better quality ?
The icons, once the documentation is generated, are not as crisp clean as they used to either, and have a green border added that wasn't there before. Image below for comparison purposes, all icons have the same problem. Would you happen to know what is causing this slight difference, that isn't very aesthetically pleasing ?
Many thanks by advance for any answer that would help me get to a solution. :)
« Last Edit: January 14, 2016, 12:33:42 am by Oopah »
Oopah
Re: HTML creation : image quality (SOLVED) and icons quality (NEWP)
« Reply #1 on: January 07, 2016, 03:46:27 am »
Found a fix for the diagram : Go to "Tools","Options", "Diagram".
In General : Tick "Zoom to best scale" , and set "Scale Saved Bitmaps at 100 %. Add to the Image Memory Limit too.
Still haven't found anything for the icons.
Oopah
Found a partial "not EA" solution replacing all the new fuzzy icons with the old pretty icons, using a homebrew PHP scripting solution once the report has been generated. It is rather inelegant, but it works.
Should anyone have an idea, or a more elegant solution, I'd be happy to take it and apply it in the future.
« Last Edit: January 14, 2016, 12:35:24 am by Oopah »
Glassboy
You could try changing the renderer on the Diagram | Appearance tab.
