Author Topic: Syntax for adding a connector?  (Read 5369 times)
Tim Twe
« on: May 25, 2010, 09:00:27 pm »
Whats the syntax for correctly adding a connector?
       var c as EA.Connector;
      c = element.Connectors.AddNew( "", "" );
      c.Alias = "Generated";
      c.Type = "CommunicationPath";
      c.ClientID = elementAlpha.ElementID;
      c.SupplierID = elementBeta.ElementID;
      c.Update();
      elementAlpha.Connectors.Refresh();
Re: Syntax for adding a connector?
« Reply #1 on: May 25, 2010, 09:36:23 pm »
You have to tell EA what type of connector you are adding.
I think the allowed parameters are strings containing the name of the type such as "Association" or "Dependency".
Look at the help page for connector to find the different types.
mrf
« Reply #2 on: May 26, 2010, 08:52:54 am »
Here's an example of how to create a connector in JScript.
 * Creates a connector between supplier and client
function createConnector( clientElement , supplierElement )
      // Assign the client and supplier IDs
      var clientID = clientElement.ElementID;
      var supplierID = supplierElement.ElementID;
      // Get the connectors collection
      var connectors as EA.Collection;
      connectors = clientElement.Connectors;
      // Create a new connector and set the appropriate details
      c = connectors.AddNew( "", "Association" );
      c.ClientID = clientID;
      c.SupplierID = supplierID;
      c.Direction( "Unspecified" );
      c.Update();
      // OPTIONAL: Set details on the connector ends
      // Set details on the client connector end
      var clientEnd as EA.ConnectorEnd;
      clientEnd = c.ClientEnd;
      clientEnd.Role = "";
      clientEnd.Cardinality = "";
      clientEnd.Navigable = true;
      clientEnd.Update();
      // Set details on the supplier connector end
      var supplierEnd as EA.ConnectorEnd;
      supplierEnd = c.SupplierEnd;
      supplierEnd.Role = "";
      supplierEnd.Cardinality = "1";
      supplierEnd.Navigable = true;
      supplierEnd.Update();
      c.Update();
« Last Edit: May 26, 2010, 08:58:08 am by mfraser »
Best Regards,
Michael
Tim Twe
« Reply #3 on: May 26, 2010, 07:23:50 pm »
That you, that is absolutely great.
You dont have a repository like http://www.exampledepot.com do you ?
-Tim
mrf
« Reply #4 on: May 27, 2010, 09:03:27 am »
EA itself ships with an example repository. Open up the Scripting window (View | Scripting from the main menu) and check out the Local Scripts group.
For more specialised scripts check out the Community Resources section of the EA Community site http://community.sparxsystems.com/resources
« Last Edit: May 27, 2010, 09:03:52 am by mfraser »
Best Regards,
Michael
