Author Topic: Re: Tagged value  (Read 11105 times)
ocean1
Re: Tagged value
« on: January 15, 2016, 01:22:20 am »
Hi all,
I have a problem with tagged value. I want to exclude the tagged value for all attributes that contain this from report.
Its name #Property. I cant do this with options in template on “Element filters”.  I think that does not work in EA :(
Could anyone help me?
Thank you!
Glassboy
Re: Tagged value
« Reply #1 on: January 15, 2016, 07:23:35 am »
Hi all,
Thank you!
Hi there, you should start your own thread with your question, not hijack someone else's.
In answer to what I think your question is, have you looked under Document Options | Element Filters | Add Filters | Attribute.AttTagValue ?
ocean1
Re: Tagged value
« Reply #2 on: January 15, 2016, 05:38:16 pm »
Hi all,
Thank you!
Yes, I saw it. But it doesnt work with any tag value's name and value.
Maybe someone saw the case like that.
Re: Tagged value
« Reply #3 on: January 15, 2016, 05:57:21 pm »
If the standard template options don't really give you what you need you may want to consider an SQL template fragment.
The query could be as simple as
select tv.Property, tv.Value, tv.Notes as Memo from t_objectProperties tv
where tv.Object_ID = #OBJECTID#
and tv.Property not in ('#Property')
There's a pretty decent learning centre (ALT-F1) article about SQL template fragments if you don't know how they work.
ocean1
Re: Tagged value
« Reply #4 on: January 15, 2016, 10:05:42 pm »
Thank you for help. I am not good in SQL queries, but it does not work because tagged values is situated on the attributes. This query show only tagged value on object type.
But how can I report list of attributes in table like? :(
| Attribute Name | Attribute Type | Attribute Tagged Values      |
|    Address         |        String      |   #Property: PropertyValue  |
« Last Edit: January 15, 2016, 10:36:14 pm by ocean1 »
Re: Tagged value
« Reply #5 on: January 15, 2016, 11:05:04 pm »
In that case you can use something similar to
select a.Name as Attribute,a.Type, tv.Property, tv.Value, tv.Notes as Memo
from (t_attributetag tv
inner join t_attribute a on tv.ElementID = a.ID)
where a.Object_ID = #OBJECTID#
and tv.Property not in ('#Property','AnotherTagToIgnore')
ocean1
Re: Tagged value
« Reply #6 on: January 18, 2016, 10:16:17 pm »
Thank you. But can I do it if template will be situate in table.
So how can I change the query?
I tried:
select tv.Property AS Name, tv.Value AS Value
from t_attributetag tv
where a.ID = #AttributeID# and tv.Property not in ('#Property')
But it does not work :(
I must report some important documents, please help
Re: Tagged value
« Reply #7 on: January 18, 2016, 10:38:46 pm »
In that case you would have to replace the whole attribute table by a query, reporting all tagged values in one field.
ocean1
Re: Tagged value
« Reply #8 on: January 19, 2016, 12:21:21 am »
I use the your query
 and I get this (1st table). But I cant change query. I need table like 2nd table(
Re: Tagged value
« Reply #9 on: January 19, 2016, 12:29:33 am »
Your query should report only one row per attribute and concatenate the names and values for all tagged values into one field.
If you find it too complicated to do in SQL you might consider switching to a script fragment. For this case that would probably be easier as you then deal with each attribute separately iso working with resultsets.
