Author Topic: Matrix Hyperlink - add Search Term  (Read 4033 times)
Tony D
« on: January 20, 2016, 05:38:58 pm »
Could we please get the Relationship Matrix hyperlink capability extended to add the Search Term.
So combine the following
$search://Name=Simple;Term=test
$matrix://profile_name
to
$matrix://Name=profile_name;Term=test
It seems there is very little control capabilities surrounding the Relationship Matrix.  I want to output a matrix of filtered objects into a document.  My objects are in different packages to the document (i.e. Use Cases in Use Case Model package, Components in Component Model package, and each document is in a separate package which contains the related views).
At least with the Model Search on Relationship Matrix I can see the relevant matrix and output it for each document.  I am trying to automate this as much as possible and thought hyperlinks would resolve it.  However I need to manually change the Search Criteria everytime I open it.  If you added the Search Term to the Hyperlink, I could have a bunch of hyperlinks which could allow me to output the different matrices with less chance of error.
