Author Topic: Use relationship  (Read 8247 times)
zyx
Use relationship
« on: January 21, 2016, 11:11:36 pm »
Dear all,
     As always, I apologize for my bad english...
     The use relationship in the use cases diagram was deprecated? I am reading the UML 2.5 formal documentation and I am founding nothing about this relationship in the section about use cases. There is no a metaclass to represent this association in the use case metamodel too. I found documentation about include and extend but nothing about the use relationship... It is no more a valid relationship to be applied in the use case diagram?
Re: Use relationship
« Reply #1 on: January 22, 2016, 02:18:00 am »
You may still use <<use>> if you find it useful (pun intended). Just create your own stereotype, describe it's meaning and you are done.
zyx
« Reply #2 on: January 22, 2016, 03:56:10 am »
Right, but the relationship is not an official relationship in UML anymore? I am just curious, old books present it as a valid relationship to be applied in the use case diagram...
« Reply #3 on: January 22, 2016, 05:14:07 am »
There is still a Usage relation defined in the meta model as a subclass of Dependency. (See UML 2.5 §7.8.23 on page 60)
It uses the «use» keyword to indicate the difference between a Usage and a regular Dependency (see the last keyword of Annex C: Keywords)
The definition says:
A Usage is a Dependency in which the client Element requires the supplier Element (or set of Elements) for its full
implementation or operation.
But I would not recommend it. I've done loads of Use Cases, and I never used the Usage, nor did I ever feel I needed something vague like that.
« Reply #4 on: January 22, 2016, 06:39:25 am »
Partially/temporarily (can't remember exactly) we used the <<use>> to indicate secondary actors. That wasn't too devious.
