Author Topic: Diagram properties with pdata in a profile  (Read 3309 times)
Hans Olthof
« on: May 28, 2010, 11:19:58 am »
I am attempting to override the appearance of element stereotypes in a diagram profile.
So far, I cannot override the appearance of Element Stereotypes.
I've created an attribute of the diagram thus:
pdata: string = HideEStereo=1
It does not work.
I've tried various capitalisations of pdata and also finally manually changing an example of the diagram, looking up the database and copying the pdata field for the diagram (where I do see the HideEStereo field swap from 0 to 1 after doing it through the UI).
Any ideas on what I am doing wrong?
with thanks,
Hans
Re: Diagram properties with pdata in a profile
« Reply #1 on: May 28, 2010, 12:28:53 pm »
Hi Hans,
I think you've left off the trailing semi-colon.  All these concatenated fields appear to terminate with a semi-colon - which appears to be mandatory.
