Author Topic: Document Generation; Problem with custom scripts when published as MDG  (Read 6561 times)
PeterHeintz
In a template fragment I call a custom script method and after generating a document all works fine.
When I use the templates and scripts in a published MDG, the script seems to be not called at all.
What I realized (when using the MDG) is, that in the “Custom Query” tab of the template fragment the method call is there but the script containing the file is not selected in the form.
Any idea to get this problem solved?
Best regards,
Peter Heintz
Re: Document Generation; Problem with custom scripts when published as MDG
« Reply #1 on: January 26, 2016, 07:42:47 pm »
Peter,
Seems like a bug to me, so please make sure to file a bug report
I think the problem stems from the fact that the reference from the scriptfragment to the script is based on the ID of the script, which seems to change when importing a script using MDG.
I don't see an immediate solution right now except for importing the scripts using "Import Reference Data"
PeterHeintz
« Reply #2 on: January 29, 2016, 12:06:18 am »
As stated by Sparx, this bug is scheduled to be fixed in V13. :)
Best regards,
Peter Heintz
« Reply #3 on: January 29, 2016, 12:20:50 am »
Thanks for the info Peter, good to know.
Uffe
« Last Edit: June 23, 2016, 09:06:17 am by KP »
