Author Topic: Custom Properties via MDG?  (Read 12845 times)
« on: January 27, 2016, 06:42:20 pm »
Most of us who play with MDG Technologies, know that the "Advanced Properties" for an element or relationship end up as CustomProperties in t_xref.
Is there any way in the MDG specification process whereby one can define a new CustomProperty?
Thomas' excellent book on MDG is, unfortunately, silent on the matter (and the Help doesn't seem to provide any answer either).
TIA,
Re: Custom Properties via MDG?
« Reply #1 on: January 27, 2016, 09:57:37 pm »
I'll have a look into that - but no promises ;)
P.S. After some fiddling around I found that it is possible to add new CPs with an INSERT statement. I had to reload EA to show them. Will need a bit more of experimenting.
P.P.S. Brake! After a consistency check the new value has been removed (claimed to be duplicate?!)
« Last Edit: January 27, 2016, 10:33:41 pm by qwerty »
« Reply #2 on: January 28, 2016, 11:32:10 am »
Thanks q,
Don't "bust a gut" getting to the bottom of it.  After a bit of a think, I decided that Custom Properties were too hard to get at... (Decoding all that text) So I opted to go for Tagged Values instead - much easier to work with "under the covers", but not as conceptually nice as custom properties.
BTW: Are Custom Properties visible in Shapescripts?  If not, then another reason for not using them.
« Last Edit: January 28, 2016, 11:36:00 am by Paolo F Cantoni »
« Reply #3 on: January 28, 2016, 09:11:45 pm »
To my knowledge only indirectly via an add-in.
« Reply #4 on: January 29, 2016, 11:00:00 am »
That's what I thought; but if you search the help for the word "triangle", in Query Methods topic, there's an example with what seems like user defined Custom Properties.  RoyC, can you comment?
« Reply #5 on: January 29, 2016, 11:21:14 am »
The only one I found was http://sparxsystems.com/enterprise_architect_user_guide/12.1/building_models/writing_scripts.html but I can't spot any custom property reference.
RoyC
  • Read The Help!
« Reply #6 on: January 29, 2016, 12:09:37 pm »
I found the text that Paolo is referring to. I can't really comment on it other than to say that it does what it says it does. Have a play with it and see if it meets your requirements.
Best Regards, Roy
« Reply #7 on: January 30, 2016, 06:38:22 am »
It would have been nice if you let others participate by posting the link  :P
RoyC
  • Read The Help!
« Reply #8 on: February 01, 2016, 09:36:04 am »
http://sparxsystems.com/enterprise_architect_user_guide/12.1/building_models/query_methods.html
The second section of the topic, HasProperty and user-selected settings.
Best Regards, Roy
« Reply #9 on: February 01, 2016, 09:44:30 am »
Ah cool, thanks. This <<diagram property>> thingy, has it been there since a longer time? Never was aware of that.
« Reply #10 on: February 01, 2016, 09:55:52 am »
I believe it was added in EA 11.1 specifically to support BPMN. From the release notes:
Diagram specific properties for Gateway marker visibility and Activity expanded added
« Reply #11 on: February 01, 2016, 09:59:27 am »
In addition to KP's comment.
There are a number of profiles that define notational options, and prior to that, the only way a user could set them was via a tagged value. Of course that meant that they couldn't vary the notation on different diagrams.
« Reply #12 on: February 01, 2016, 09:06:36 pm »
Cheers :-) i'll have to look into that.
