Author Topic: Floating Licence on AWS VM  (Read 4904 times)
philchudley
« on: January 30, 2016, 01:37:49 am »
Hi All
Has anyone had any success in locating floating licences on an AWS VM EC2 Windows 2008 server instance?
I ask because a client on mine has tried and failed.
EA fails to connect to the AWS VM using a elastic IP address (which is static and does not change)
The Security Group for the AWS VM are set to accept incoming TCP on all from all hosts
Have also set firewall rules to allow access via 7770 on bot the VM and the client machine
Any advice most welcome
Cheers
Phil
« Last Edit: January 30, 2016, 01:43:04 am by philchudley »
Models are great!
redmanda
Re: Floating Licence on AWS VM
« Reply #1 on: January 23, 2018, 07:52:07 am »
I am having the same issue. I will start a new thread since this one is pretty old.
