Author Topic: Poor diagram image quality in Web (HTML) Reports.  (Read 13102 times)
Svend Erik Nygaard
  • Business Information Architect
« on: February 02, 2016, 12:45:02 am »
My HTML reports show blurred diagrams (both text and lines).
I have included an example below of how my Web report diagrams look like.
I have tried many different combinations of settings (Image Format in html report window; Scale Saved Bitmaps to %; Image Memory Limit MB; Renderer; GDI Plus Meta-files; Scale view by %; Anti-aliased text; Compress text to fit within Element; Clipboard image format; ...)
But I have not found the cause of the poor image quality.
So please anyone - help :-)  What are the important settings and their values for geting proper image quality og diagram images in Web reports
(I did see http://sparxsystems.com/forums/smf/index.php/topic,25943.0.html - but that did not help me.)
« Last Edit: February 02, 2016, 12:46:44 am by Svend Erik Nygaard »
Re: Poor diagram image quality in Web (HTML) Reports.
« Reply #1 on: February 02, 2016, 12:55:31 am »
Svend,
I'm looking at the image you posted, but it looks crystal clear to me. ???
Svend Erik Nygaard
« Reply #2 on: February 02, 2016, 01:00:08 am »
Even if you compare the text in the image to the text (html) in the post?
« Reply #3 on: February 02, 2016, 01:06:44 am »
Yes,
I would even say that the text of the forum is slightly blurrier then the text in the image.
Svend Erik Nygaard
« Reply #4 on: February 02, 2016, 01:34:17 am »
Great Geert,
can you please send me 400 clones of your Workstation  ;D
Ok back to serious: Unfortunately the workstations, I have tested this on presents blurry diagrams where the clean HTML text is sharper than the diagrams.
Are there more people out there - how does the diagram present itself on your workstation?
« Last Edit: February 02, 2016, 01:37:49 am by Svend Erik Nygaard »
Glassboy
« Reply #5 on: February 02, 2016, 06:44:26 am »
The graphic looks fine on both my monitor.  If you're running on a recent version of Windows the resolution options for your monitor should have one with "(recommended)" next to it.  Make sure you're using that one and not another choice with a different aspect ratio.  If you're running your monitor in the wrong aspect ratio it will cause distortion in text on images.
HarryPlotter
« Reply #6 on: February 02, 2016, 11:58:40 am »
Suggest also look at which app is rendering the html.
A client I work at recently rolled out IE11 as part of their 'standard operating environment'. Result was some SharePoint wikis now look really messy - all the sanserif fonts spaced/kerned poorly, and some images scaled in very imaginative ways.
I just saved your PNG - in the client environment, it appears to be very sharp in 'Windows Photo Viewer' and slightly blurred in 'IE11'.
AndyJ
  • It's only a model
« Reply #7 on: February 02, 2016, 03:59:59 pm »
Same here, crystal clear in Firefox.
Svend Erik Nygaard
« Reply #8 on: February 04, 2016, 12:57:22 am »
Thank you very much everyone who took time to respond to this.
I'm still not happy with the image quality - and yes, I realize that it is an image and not vector graphics - but still.
But, at least I now know that it is not because I have set op options that affects the image quality negatively compared to what is to be expected.
My screen resolutions on my own workstations screens are "2560 x 1600 (recommended)", and I have seen it on several other workstations as well.
But again - I am impressed with your willingness to take time to respond, thanks a lot guys   :)
Dermot
« Reply #9 on: February 04, 2016, 02:12:50 pm »
With your Windows | Control Panel | Display options - do you have this set to another Size for Items - not 100%.
If so, try setting it back to 100% and check for any difference.
Svend Erik Nygaard
« Reply #10 on: May 10, 2016, 10:29:01 pm »
Thanks, Dermot - only saw your message just now.  - However, it was set to 100%.
