Author Topic: Using EA floating licences in 'mixed' mode  (Read 4087 times)
mreb
« on: February 03, 2016, 06:56:15 am »
Hi, I would like to implement the 'mixed' mode for floating licenses - setting up two key stores, one for mobile users and one for desktop users, as mentioned in pages 22-23 of the SSKeyStoreUG.pdf.  I haven't found instructions on how to do this, however, that is not file-based.  Can I create two network-based key stores that are running on the same machine, or will one have to be filed-based?
Re: Using EA floating licences in 'mixed' mode
« Reply #1 on: February 03, 2016, 08:35:40 am »
Unfortunately, the server can only be run once, hosting a single keystore on a machine.
mreb
« Reply #2 on: February 04, 2016, 01:08:23 am »
Hi Simon,
Appreciate the response!  So would you say there are two ways to go about it:
1. Set up the other key store on another server
2. Set up the other keys as a file-based key store
Is #2 not recommended at all?
Thanks!
« Reply #3 on: February 04, 2016, 09:02:28 am »
You can do #2, but back up the file. It's likely to get corrupted at some point.
