Author Topic: Connector Labels not fully selectable, if overridden  (Read 3758 times)
« on: February 10, 2016, 12:54:01 pm »
If the connector Source Labels (SourceTopLabel and SourceBottomLabel) are created by the connector NativeShape (say source multiplicity on an Association) then they are selectable and manipulable - in the normal way.
However, if they are overridden by a shapescript label method, they aren't properly selectable. In particular, the selection handles to allow you to resize the label aren't available.
I assume this also applies to the Target labels.
Reported,
Inconsistent behaviour!
« Reply #1 on: February 10, 2016, 03:20:46 pm »
Curioser and Curioser!
Some labels (of the same type, in this case: Source Bottom Label (aka: LeftBottomLabel)) ARE selectable as per normal, others aren't!  Haven't tracked down the reason why some aren't.
Definite EAUI!
