Author Topic: Error creating a database repository using Oracle_EASchema.sql on Oracle 11.2  (Read 5816 times)
EAForum1
Trying to run the database repository creation script Oracle_EASchema.sql on an Oracle 11.2 instance, I get the error detailed below.
I suspect this may have to do with the bit <<<"LASTUPDATE"    VARCHAR2(19) DEFAULT SYSDATE>>>, since SYSDATE is of datatype date, not latching the column type (VARCHAR2)?
Has this issue been encountered by others already?
Thank you,
Didier
Error details:
Error starting at line : 917 in command -
CREATE TABLE "T_OBJECTREQUIRES"
    "REQID"         NUMBER(10,0),
                "OBJECT_ID"     NUMBER(10,0) DEFAULT 0 NOT NULL,
                "REQUIREMENT"   VARCHAR2(255),
                "REQTYPE"       VARCHAR2(255),
                "STATUS"        VARCHAR2(50),
                "NOTES"         CLOB,
                "STABILITY"     VARCHAR2(50),
                "DIFFICULTY"    VARCHAR2(50),
                "PRIORITY"      VARCHAR2(50),
                "LASTUPDATE"    VARCHAR2(19) DEFAULT SYSDATE,
                CONSTRAINT "PK_OBJECTREQUIRES" PRIMARY KEY ("REQID")
Error report -
SQL Error: ORA-01401: inserted value too large for column
01401. 00000 -  "inserted value too large for column"
*Cause:    The value inserted was too large for the given column.
*Action:   Do not insert a value greater than what the column can hold.
Error starting at line : 932 in command -
CREATE INDEX "IX_OBJREQ_OBJECTID" ON "T_OBJECTREQUIRES" ("OBJECT_ID")
Error report -
SQL Error: ORA-00942: table or view does not exist
00942. 00000 -  "table or view does not exist"
*Cause:
*Action:
Error starting at line : 934 in command -
CREATE INDEX "IX_OBJREQ_REQ" ON "T_OBJECTREQUIRES" ("REQUIREMENT")
Error report -
*Cause:
*Action:
onlyonce
What is your result?
SELECT to_char(SYSDATE) FROM dual
