Author Topic: Code Template Macros: How can I escape \t (tab) character?  (Read 5937 times)
baron52
« on: February 13, 2016, 05:41:41 am »
Hi!
I am writing a code template that contains JavaScript processing rules.  My issue is that I want to check if data being processed has \t (tab) like this:
if(lines[i].indexof('\t')>0){//do something}  However, the generator does not seem to know how to escape tabs (I could not find a macro for this in docs either).  Is there a solution/workaround for this?
Robert
MMA
Re: Code Template Macros: How can I escape \t (tab) character?
« Reply #1 on: February 17, 2016, 09:47:38 am »
I tried your template and generated
if(lines[i].indexof(' ')>0){//do something}
Although the following trick works, Aaron's Answer is much better.
if(lines.indexof('%TO_LOWER("\T")%')>0){//do something}
Then it will generate
« Last Edit: February 17, 2016, 10:01:41 am by MMA »
Aaron B
« Reply #2 on: February 17, 2016, 09:57:29 am »
Or use %sl% to output the backslash character ...
if(lines[i].indexof('%sl%t')>0){//do something}
See:
http://sparxsystems.com/enterprise_architect_user_guide/12.1/software_engineering/literaltext.html
baron52
« Reply #3 on: February 18, 2016, 06:08:12 am »
Awesome.  Thanks!
