Author Topic: Code Engineering when import code, Does it generate Sequence diagram  (Read 7409 times)
Lalitha
I noticed that class diagram gets generated.  Not sure if Sequence diagram can be created.
Helmut Ortmann
Re: Code Engineering when import code, Does it generate Sequence diagram
« Reply #1 on: February 15, 2016, 03:43:39 am »
Sequence diagrams usually are scenarios which specifies your problem at hand.
If you try to depict everything what your application, function or hardware does you see in essence nothing.
Generating Sequence Diagrams mostly makes no real sence.
I don't know of such a function.
Helmut
Uffe
« Reply #2 on: February 15, 2016, 07:34:11 pm »
There is a way to generate sequence diagrams, though not from source code.
Sequences can be recorded from executing code by attaching EA to a process like you would a debugger.
See Generating Sequence Diagrams.
Cheers,
/Uffe
