Author Topic: UML class to SysML block  (Read 8603 times)
royvanmarrewijk
« on: February 16, 2016, 01:19:06 am »
We just discovered that a teammember created a lot of UML class type elements where our conventions tells us to use SysML1.3 type elements. :o Can anyone tell me if there is a standard EA function which I can use to convert the UML Class to a SysML1.3 Block?
Roy
Re: UML class to SysML block
« Reply #1 on: February 16, 2016, 01:58:35 am »
Select element in diagram, then use menu option
Element|Advanced|Change Type to the underlying type of a SysML block
Then add the appropriate SysML stereotype to the element.
« Reply #2 on: February 16, 2016, 07:59:55 am »
You might run a script and assign the correct stereotype. That should also do the trick.
« Reply #3 on: February 16, 2016, 08:38:25 am »
You can simply drag the SysML block stereotype from the toolbox onto a diagram object (as long as it's a Class). When asked, choose "Apply".
royvanmarrewijk
« Reply #4 on: February 16, 2016, 05:55:27 pm »
Guys,
Thanks for your quick and helpfull reactions!! This really helped me out.
Roy
