Author Topic: CSV Import Character Encoding  (Read 13380 times)
WzDrg
« on: February 17, 2016, 07:49:22 pm »
We have problems importing CSV files with special characters into enterprise architect.
What encoding should we use?
Re: CSV Import Character Encoding
« Reply #1 on: February 17, 2016, 08:58:38 pm »
You should probably switch to Jet4. See Tools/Options/General. Additionally you might need replace your EABase.eap in the EA program folder with the Jet4 version which is available somewhere on Sparx' site.
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: February 18, 2016, 10:58:33 am »
Hello WzDrg,
You can specify encoding for importing CSV file from the Main menu | Tools | Options | Source Code Engineering | Code page for source.
(This option is available for both source code and CSV file.)
t-kouno
rampatter
« Reply #3 on: December 27, 2016, 06:23:27 pm »
Check this one, more about...character encoding
stevesavage
« Reply #4 on: September 19, 2018, 03:30:26 am »
Hello WzDrg,
Anyone know where this option is hidden in EA14, I've been looking and can't find it under the Code or Configure ribbons.
RoyC
  • Read The Help!
« Reply #5 on: September 20, 2018, 02:07:38 pm »
Try the ribbon Publish > Model Exchange > CSV > CSV Import/Export.
For source code, look at the ribbon Configure > Model > Options > Source Code Engineering
Best Regards, Roy
stevesavage
« Reply #6 on: September 21, 2018, 02:00:11 am »
Thanks Roy, it's under Source Code Engineering.
