Author Topic: "Note" Element from Common Toolbox has changed  (Read 11410 times)
tonyabs
« on: February 18, 2016, 11:32:50 am »
Tried a search and could not find similar, though may not have used right keywords.
Somehow I have done something to cause the "Note" element in the Toolbox Common to now appear first as a Note with default text rather than blank like it should be.
Pretty sure I have done nothing abnormal as far as creating diagrams etc. So wonder if anyone else experienced similar.
Also have had a similar problem for someone else in past where a Text element now behaves like a Hyperlink.
Have a common repository buuilt on Oracle using EA v11 (moving to 12 soon)
Re: "Note" Element from Common Toolbox has changed
« Reply #1 on: February 18, 2016, 11:42:52 am »
I suspect you have set a Project Template Package. Go "Main Menu > Settings > Project Template Package" (in EA 11) to find out which package, then open the diagram(s) in that package to see what default text you have defined for note elements.
RoyC
  • Read The Help!
« Reply #2 on: February 18, 2016, 11:52:31 am »
KP's comment would also apply to the Text element, I think, but there is also a small chance that the Note element has been set to a different appearance. If the default text is "Modified on <date>", the Note has been put in Memo format. Right-click on the Note and select the 'Appearance' context menu option, and see if any of the appearance formats have been selected.
Best Regards, Roy
tonyabs
« Reply #3 on: February 18, 2016, 11:59:37 am »
Karma Thanks!!! A bit of user guide reading and you are right. Learn something new every day. Problem solved in this cas by setting project template back to <none> ie back to defaults.
Will know to be more carefull with this feature in future.
