Author Topic: Script fragment error only on first try  (Read 6541 times)
« on: February 26, 2016, 06:28:50 pm »
I have  a weird problem that I can't seem to get my head around.
I'm using RTF templates with some script fragments. Now usually the first time I generate a document I get an error (or more) and some of the content from the script fragments has not been generated. Not all of it mind you. Some parts (using the same script fragment template) generate just fine, but other don't.
When I try that a second time it (almost always) generates perfectly fine.
What do they say again about someone who does exactly the same thing but expects a different outcome ???
It feels like the script engine has to "warm up" before it is ready to really do the job. :-\
Running the script manually always works just fine.
Anyone had the same problem, or has an idea how to solve it?
Anyway here's the script I use in the script fragment
'[path=\Projects\Project A\Template fragments]
'[group=Template fragments]
option explicit
!INC Local Scripts.EAConstants-VBScript
!INC Atrias Scripts.Util
' Script Name:
' Author:
' Purpose:
' Date:
function MyPackageRtfData(packageID, tagname)
dim package as EA.Package
dim element as EA.Element
set package = Repository.GetPackageByID(packageID)
if not package is nothing then
set element = Repository.GetElementByGuid(package.PackageGUID)
if not element is nothing then
MyPackageRtfData = MyRtfData (element.ElementID, tagname)
end if
end if
end function
function MyRtfData (objectID, tagname)
dim xmlDOM
'set  xmlDOM = CreateObject( "Microsoft.XMLDOM" )
set  xmlDOM = CreateObject( "MSXML2.DOMDocument.4.0" )
xmlDOM.validateOnParse = false
xmlDOM.async = false
dim node
set node = xmlDOM.createProcessingInstruction( "xml", "version='1.0'")
    xmlDOM.appendChild node
dim xmlRoot
set xmlRoot = xmlDOM.createElement( "EADATA" )
xmlDOM.appendChild xmlRoot
dim xmlDataSet
set xmlDataSet = xmlDOM.createElement( "Dataset_0" )
xmlRoot.appendChild xmlDataSet
dim xmlData
set xmlData = xmlDOM.createElement( "Data" )
xmlDataSet.appendChild xmlData
dim xmlRow
set xmlRow = xmlDOM.createElement( "Row" )
xmlData.appendChild xmlRow
set element = Repository.GetElementByID(objectID)
dim formattedAttr
set formattedAttr = xmlDOM.createAttribute("formatted")
formattedAttr.nodeValue="1"
dim descriptionfull
descriptionfull = getTagContent(element.Notes, tagname)
dim xmlDescNL
set xmlDescNL = xmlDOM.createElement( "DescriptionNL" )
xmlDescNL.text = getTagContent(descriptionfull, "NL")
xmlDescNL.setAttributeNode(formattedAttr)
xmlRow.appendChild xmlDescNL
dim xmlDescFR
set xmlDescFR = xmlDOM.createElement( "DescriptionFR" )
xmlDescFR.text = getTagContent(descriptionfull, "FR")
xmlDescFR.setAttributeNode(formattedAttr)
xmlRow.appendChild xmlDescFR
MyRtfData = xmlDOM.xml
end function
'msgbox MyPackageRtfData(3357,"")
function test
dim outputString
dim fileSystemObject
dim outputFile
outputString =  MyRtfData(62899, "definition")
set fileSystemObject = CreateObject( "Scripting.FileSystemObject" )
set outputFile = fileSystemObject.CreateTextFile( "c:\\temp\\NLFRtest.xml", true )
outputFile.Write outputString
outputFile.Close
end function
'test
